標題: [求助] 如何更改APACHE日志的格式? [打印本頁]
作者: tiantangld    時間: 2012-6-9 12:13     標題: 如何更改APACHE日志的格式?
近日想更改APACHE日志的格式,使其能記錄訪客的User-Agent信息到日志里,但是百度了很多資料,還是沒能學會
現(xiàn)在的日志記錄下來是這樣:
  1. 10.1.1.95 - e800 [18/Mar/2005:12:21:42 +0800] "GET /stats/awstats.pl?config=e800 HTTP/1.1" 200 899
復制代碼
我想改成這樣:
  1. 10.1.1.95 - e800 [18/Mar/2005:12:21:42 +0800] "GET /stats/awstats.pl?config=e800 HTTP/1.1" 200 899 "http://10.1.1.1/pv/" "Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; Maxthon)"
復制代碼
哪位大哥知道怎么修改呢?
以下為小弟http.conf的部分信息,不知道是不是改這里?
  1. <IfModule log_config_module>
  2.     #
  3.     # The following directives define some format nicknames for use with
  4.     # a CustomLog directive (see below).
  5.     #
  6.     LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
  7.     LogFormat "%h %l %u %t \"%r\" %>s %b" common
  8.     <IfModule logio_module>
  9.       # You need to enable mod_logio.c to use %I and %O
  10.       LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\" %I %O" combinedio
  11.     </IfModule>
  12.     #
  13.     # The location and format of the access logfile (Common Logfile Format).
  14.     # If you do not define any access logfiles within a <VirtualHost>
  15.     # container, they will be logged here.  Contrariwise, if you *do*
  16.     # define per-<VirtualHost> access logfiles, transactions will be
  17.     # logged therein and *not* in this file.
  18.     #
  19.     CustomLog "logs/access_log" common
  20.     #
  21.     # If you prefer a logfile with access, agent, and referer information
  22.     # (Combined Logfile Format) you can use the following directive.
  23.     #
  24.     #CustomLog "logs/access_log" combined
  25. </IfModule>
復制代碼
作者: admin    時間: 2012-6-9 15:37
改為
就可以
作者: tiantangld    時間: 2012-6-9 18:32
回復 2# admin
    非常感謝
作者: tiantangld    時間: 2012-6-9 23:29
回復 2# admin
    老大,我試著更改重啟了還是不行哦,是不是我改錯哪里了,麻煩老大幫忙在看一下
我更改后,日志還是這樣子的
  1. 95.211.139.1 - - [09/Jun/2012:23:16:04 +0800] "GET /store/shoplist-14.html HTTP/1.0" 200 -
復制代碼
最后附httpd.conf
  2.     #
  5.     #
  11.     </IfModule>
  12.     #
  18.     #
  19.     CustomLog "logs/access_log" combined
  20.     #
  23.     #
  25. </IfModule>
  26. <IfModule alias_module>
復制代碼
作者: admin    時間: 2012-6-10 00:36
這樣是對的
作者: tiantangld    時間: 2012-6-10 01:38
回復 5# admin
    終于找到問題所在了,單單修改這里還不行,還要去修改虛擬主機配置文件
作者: admin    時間: 2012-6-10 10:36
這個是默認的記錄文件,也是所有的
虛擬主機里的是針對站點的
