麻煩大家?guī)臀铱聪耉PS什么情況,謝謝
[打印本頁(yè)]
aquan888
2014-8-2 20:37
每天都死機(jī)一次,重啟后正常。
Aug 2 10:55:27 localhost kernel: INFO: task httpd:2613 blocked for more than 120 seconds.
Aug 2 10:55:27 localhost kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Aug 2 10:55:27 localhost kernel: httpd D 0000000000000000 0 2613 1388 0x00000080
Aug 2 10:55:27 localhost kernel: ffff88007d769e38 0000000000000082 ffff88007d769df8 ffffffff8114431a
Aug 2 10:55:27 localhost kernel: ffff88007d769e38 ffffffff81148336 ffff88007ae4c040 0000000000000028
Aug 2 10:55:27 localhost kernel: ffff88007ae4c5f8 ffff88007d769fd8 000000000000fb88 ffff88007ae4c5f8
Aug 2 10:55:27 localhost kernel: Call Trace:
Aug 2 10:55:27 localhost kernel: [<ffffffff8114431a>] ? handle_mm_fault+0x23a/0x310
Aug 2 10:55:27 localhost kernel: [<ffffffff81148336>] ? vma_adjust+0x556/0x5e0
Aug 2 10:55:27 localhost kernel: [<ffffffff8104757c>] ? __do_page_fault+0x1ec/0x480
Aug 2 10:55:27 localhost kernel: [<ffffffff8127d95c>] ? rb_erase+0x1bc/0x310
Aug 2 10:55:27 localhost kernel: [<ffffffff8150fc45>] rwsem_down_failed_common+0x95/0x1d0
Aug 2 10:55:27 localhost kernel: [<ffffffff8100988e>] ? __switch_to+0x26e/0x320
Aug 2 10:55:27 localhost kernel: [<ffffffff8150fda3>] rwsem_down_write_failed+0x23/0x30
Aug 2 10:55:27 localhost kernel: [<ffffffff812833e3>] call_rwsem_down_write_failed+0x13/0x20
Aug 2 10:55:27 localhost kernel: [<ffffffff8150f2a2>] ? down_write+0x32/0x40
Aug 2 10:55:27 localhost kernel: [<ffffffff81149df0>] sys_brk+0x40/0x130
Aug 2 10:55:27 localhost kernel: [<ffffffff8100b072>] system_call_fastpath+0x16/0x1b
Aug 2 12:28:55 localhost pure-ftpd: (?@222.174.27.98) [INFO] 自 222.174.27.98 的新連接
Aug 2 12:28:59 localhost pure-ftpd: (?@222.174.27.98) [WARNING] 使用者[anonymous]驗(yàn)證失敗
Aug 2 12:28:59 localhost pure-ftpd: (?@222.174.27.98) [INFO] 登出.
Aug 2 16:35:29 localhost kernel: mysqld invoked oom-killer: gfp_mask=0x201da, order=0, oom_adj=0, oom_score_adj=0
Aug 2 16:35:29 localhost kernel: mysqld cpuset=/ mems_allowed=0
Aug 2 16:35:29 localhost kernel: Pid: 2490, comm: mysqld Not tainted 2.6.32-358.el6.x86_64 #1
Aug 2 16:35:30 localhost kernel: Call Trace:
Aug 2 16:35:30 localhost kernel: [<ffffffff8111cd10>] ? dump_header+0x90/0x1b0
Aug 2 16:35:30 localhost kernel: [<ffffffff810cc671>] ? cpuset_mems_allowed_intersects+0x21/0x30
Aug 2 16:35:30 localhost kernel: [<ffffffff8111d192>] ? oom_kill_process+0x82/0x2a0
Aug 2 16:35:30 localhost kernel: [<ffffffff8111d0d1>] ? select_bad_process+0xe1/0x120
Aug 2 16:35:30 localhost kernel: [<ffffffff8111d5d0>] ? out_of_memory+0x220/0x3c0
Aug 2 16:35:30 localhost kernel: [<ffffffff8112c27c>] ? __alloc_pages_nodemask+0x8ac/0x8d0
Aug 2 16:35:30 localhost kernel: [<ffffffff8116087a>] ? alloc_pages_current+0xaa/0x110
Aug 2 16:35:30 localhost kernel: [<ffffffff8111a0f7>] ? __page_cache_alloc+0x87/0x90
Aug 2 16:35:30 localhost kernel: [<ffffffff81119ade>] ? find_get_page+0x1e/0xa0
Aug 2 16:35:30 localhost kernel: [<ffffffff8111b0b7>] ? filemap_fault+0x1a7/0x500
Aug 2 16:35:30 localhost kernel: [<ffffffff811430b4>] ? __do_fault+0x54/0x530
Aug 2 16:35:30 localhost kernel: [<ffffffff81143687>] ? handle_pte_fault+0xf7/0xb50
Aug 2 16:35:30 localhost kernel: [<ffffffff81434551>] ? sock_aio_read+0x1a1/0x1b0
Aug 2 16:35:30 localhost kernel: [<ffffffff8114431a>] ? handle_mm_fault+0x23a/0x310
Aug 2 16:35:30 localhost kernel: [<ffffffff810474c9>] ? __do_page_fault+0x139/0x480
Aug 2 16:35:30 localhost kernel: [<ffffffff8118eb05>] ? putname+0x35/0x50
Aug 2 16:35:30 localhost kernel: [<ffffffff8151311e>] ? do_page_fault+0x3e/0xa0
Aug 2 16:35:30 localhost kernel: [<ffffffff815104d5>] ? page_fault+0x25/0x30
Aug 2 16:35:30 localhost kernel: Mem-Info:
Aug 2 16:35:30 localhost kernel: Node 0 DMA per-cpu:
Aug 2 16:35:30 localhost kernel: CPU 0: hi: 0, btch: 1 usd: 0
Aug 2 16:35:30 localhost kernel: CPU 1: hi: 0, btch: 1 usd: 0
Aug 2 16:35:30 localhost kernel: CPU 2: hi: 0, btch: 1 usd: 0
Aug 2 16:35:30 localhost kernel: CPU 3: hi: 0, btch: 1 usd: 0
Aug 2 16:35:30 localhost kernel: Node 0 DMA32 per-cpu:
Aug 2 16:35:30 localhost kernel: CPU 0: hi: 186, btch: 31 usd: 127
Aug 2 16:35:30 localhost kernel: CPU 1: hi: 186, btch: 31 usd: 3
Aug 2 16:35:30 localhost kernel: CPU 2: hi: 186, btch: 31 usd: 30
Aug 2 16:35:30 localhost kernel: CPU 3: hi: 186, btch: 31 usd: 59
Aug 2 16:35:30 localhost kernel: active_anon:44117 inactive_anon:44222 isolated_anon:0
Aug 2 16:35:30 localhost kernel: active_file:250 inactive_file:441 isolated_file:0
Aug 2 16:35:30 localhost kernel: unevictable:0 dirty:0 writeback:9 unstable:0
Aug 2 16:35:30 localhost kernel: free:13268 slab_reclaimable:2752 slab_unreclaimable:17010
Aug 2 16:35:30 localhost kernel: mapped:272 shmem:40 pagetables:31596 bounce:0
Aug 2 16:35:30 localhost kernel: Node 0 DMA free:8356kB min:332kB low:412kB high:496kB active_anon:3164kB inactive_anon:3352kB active_file:32kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15308kB mlocked:0kB dirty:0kB writeback:0kB mapped:20kB shmem:0kB slab_reclaimable:16kB slab_unreclaimable:140kB kernel_stack:32kB pagetables:448kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:10 all_unreclaimable? yes
Aug 2 16:35:30 localhost kernel: lowmem_reserve[]: 0 2004 2004 2004
Aug 2 16:35:30 localhost kernel: Node 0 DMA32 free:44716kB min:44720kB low:55900kB high:67080kB active_anon:173304kB inactive_anon:173536kB active_file:968kB inactive_file:1764kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:2052256kB mlocked:0kB dirty:0kB writeback:36kB mapped:1068kB shmem:160kB slab_reclaimable:10992kB slab_unreclaimable:67900kB kernel_stack:5048kB pagetables:125936kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:2848 all_unreclaimable? yes
Aug 2 16:35:30 localhost kernel: lowmem_reserve[]: 0 0 0 0
Aug 2 16:35:30 localhost kernel: Node 0 DMA: 21*4kB 7*8kB 2*16kB 3*32kB 3*64kB 6*128kB 4*256kB 2*512kB 3*1024kB 1*2048kB 0*4096kB = 8396kB
Aug 2 16:35:30 localhost kernel: Node 0 DMA32: 93*4kB 145*8kB 711*16kB 488*32kB 129*64kB 20*128kB 1*256kB 2*512kB 2*1024kB 1*2048kB 0*4096kB = 44716kB
Aug 2 16:35:30 localhost kernel: 3742 total pagecache pages
Aug 2 16:35:30 localhost kernel: 2898 pages in swap cache
Aug 2 16:35:30 localhost kernel: Swap cache stats: add 797897, delete 794999, find 242987/266112
Aug 2 16:35:30 localhost kernel: Free swap = 0kB
Aug 2 16:35:30 localhost kernel: Total swap = 2097144kB
Aug 2 16:35:30 localhost kernel: 524272 pages RAM
Aug 2 16:35:30 localhost kernel: 43780 pages reserved
Aug 2 16:35:30 localhost kernel: 195317 pages shared
Aug 2 16:35:30 localhost kernel: 461089 pages non-shared
Aug 2 16:35:30 localhost kernel: [ pid ] uid tgid total_vm rss cpu oom_adj oom_score_adj name
Aug 2 16:35:30 localhost kernel: [ 459] 0 459 2725 19 0 -17 -1000 udevd
Aug 2 16:35:30 localhost kernel: [ 1119] 0 1119 23300 79 0 -17 -1000 auditd
Aug 2 16:35:30 localhost kernel: [ 1135] 0 1135 62272 108 1 0 0 rsyslogd
Aug 2 16:35:30 localhost kernel: [ 1175] 0 1175 16100 63 3 -17 -1000 sshd
Aug 2 16:35:30 localhost kernel: [ 1388] 0 1388 31773 497 1 0 0 httpd
Aug 2 16:35:30 localhost kernel: [ 1400] 0 1400 12012 69 0 0 0 nginx
Aug 2 16:35:30 localhost kernel: [ 1415] 0 1415 37854 20 0 0 0 pure-ftpd
Aug 2 16:35:30 localhost kernel: [ 1423] 0 1423 28133 38 3 0 0 httpd
Aug 2 16:35:30 localhost kernel: [ 1431] 0 1431 29312 42 0 0 0 crond
Aug 2 16:35:31 localhost kernel: [ 1444] 0 1444 1016 15 1 0 0 mingetty
Aug 2 16:35:31 localhost kernel: [ 1446] 0 1446 1016 15 1 0 0 mingetty
Aug 2 16:35:31 localhost kernel: [ 1448] 0 1448 1016 15 1 0 0 mingetty
Aug 2 16:35:31 localhost kernel: [ 1450] 0 1450 2724 18 3 -17 -1000 udevd
Aug 2 16:35:31 localhost kernel: [ 1451] 0 1451 2724 16 2 -17 -1000 udevd
Aug 2 16:35:31 localhost kernel: [ 1452] 0 1452 1016 15 3 0 0 mingetty
Aug 2 16:35:31 localhost kernel: [ 1454] 0 1454 1016 15 3 0 0 mingetty
Aug 2 16:35:31 localhost kernel: [ 1456] 0 1456 1016 15 2 0 0 mingetty
Aug 2 16:35:31 localhost kernel: [ 1799] 1000 1799 12199 331 3 0 0 nginx
Aug 2 16:35:31 localhost kernel: [ 1800] 1000 1800 12016 291 0 0 0 nginx
Aug 2 16:35:31 localhost kernel: [ 1801] 1000 1801 12190 263 2 0 0 nginx
Aug 2 16:35:31 localhost kernel: [ 1804] 1000 1804 33039 296 0 0 0 httpd
aquan888
2014-8-2 20:37
Aug 2 16:35:31 localhost kernel: [ 1889] 0 1889 2826 23 1 0 0 mysqld_safe
Aug 2 16:35:31 localhost kernel: [ 2077] 27 2077 163205 1813 2 0 0 mysqld
Aug 2 16:35:31 localhost kernel: [ 2610] 1000 2610 32886 308 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 2624] 1000 2624 33091 310 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 2626] 1000 2626 32823 316 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 2633] 1000 2633 32881 314 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 2635] 1000 2635 32821 313 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 2636] 1000 2636 33092 306 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 2643] 1000 2643 33033 314 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 2648] 1000 2648 33095 322 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 2662] 1000 2662 33159 306 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 2673] 1000 2673 33090 317 2 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 2674] 1000 2674 34409 313 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 2676] 1000 2676 32813 329 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 2677] 1000 2677 33602 306 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 2682] 1000 2682 32953 319 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 2688] 1000 2688 32888 313 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 2690] 1000 2690 33613 314 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 2697] 1000 2697 33350 309 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 2699] 1000 2699 34345 320 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 2705] 1000 2705 32749 306 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 2706] 1000 2706 33331 304 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 2707] 1000 2707 33022 308 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 2717] 1000 2717 32755 306 3 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 2720] 1000 2720 32685 309 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 2727] 1000 2727 33182 315 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 2733] 1000 2733 32949 310 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 2735] 1000 2735 32951 318 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 2976] 999 2976 29415 26 3 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 2980] 999 2980 29415 26 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 3183] 1000 3183 32814 423 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 3184] 1000 3184 32796 354 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 3185] 1000 3185 32601 407 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 3186] 1000 3186 32825 356 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 3187] 1000 3187 33083 366 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 3188] 1000 3188 32821 369 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 3197] 1000 3197 32346 405 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 3198] 1000 3198 32336 431 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 3205] 1000 3205 32683 403 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 3206] 1000 3206 32759 380 0 0 0 httpd
Aug 2 16:35:31 localhost kernel: [ 3207] 1000 3207 32336 431 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3208] 1000 3208 32336 431 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3209] 1000 3209 32816 422 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3218] 1000 3218 32755 404 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3219] 1000 3219 32818 346 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3226] 1000 3226 33013 361 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3235] 1000 3235 32963 351 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3236] 1000 3236 32947 378 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3237] 1000 3237 32825 350 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3238] 1000 3238 32479 397 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3239] 1000 3239 32336 431 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3240] 1000 3240 32755 404 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3241] 1000 3241 32336 431 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3242] 1000 3242 32695 364 2 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3243] 1000 3243 32695 372 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3244] 1000 3244 32818 342 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3245] 1000 3245 32730 430 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3246] 1000 3246 32886 427 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3247] 1000 3247 32336 431 2 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3248] 1000 3248 32695 372 2 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3249] 1000 3249 32336 431 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3250] 1000 3250 32336 431 2 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3251] 1000 3251 32336 431 2 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3252] 1000 3252 32336 431 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3253] 1000 3253 32730 403 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3254] 1000 3254 33279 323 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3255] 1000 3255 32336 431 2 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3256] 1000 3256 32730 430 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3257] 1000 3257 32344 430 2 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3260] 1000 3260 33289 335 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3261] 1000 3261 33214 358 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3262] 1000 3262 32817 380 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3263] 1000 3263 33222 413 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3264] 1000 3264 32728 398 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3265] 1000 3265 32732 426 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3266] 1000 3266 32336 431 2 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3267] 1000 3267 33153 333 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3268] 1000 3268 32792 406 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3269] 1000 3269 33087 344 0 0 0 httpd
aquan888
2014-8-2 20:38
Aug 2 16:35:32 localhost kernel: [ 3270] 1000 3270 33024 338 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3271] 1000 3271 33087 359 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3272] 1000 3272 32726 406 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3273] 1000 3273 32958 356 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3274] 1000 3274 32825 355 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3275] 1000 3275 32730 427 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3276] 1000 3276 32984 365 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3277] 1000 3277 32661 427 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3278] 1000 3278 33019 353 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3279] 1000 3279 32600 360 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3280] 1000 3280 33152 326 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3281] 1000 3281 32794 366 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3282] 1000 3282 33339 329 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3283] 1000 3283 32796 426 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3284] 1000 3284 32827 371 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3285] 1000 3285 33222 424 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3286] 1000 3286 33219 331 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3287] 1000 3287 32600 357 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3288] 1000 3288 32661 430 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3289] 1000 3289 32829 348 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3290] 1000 3290 32669 426 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3291] 1000 3291 32344 431 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3292] 1000 3292 32800 367 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3293] 1000 3293 32732 427 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3294] 1000 3294 32669 429 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3295] 1000 3295 32730 430 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3296] 1000 3296 33341 350 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3297] 1000 3297 33346 361 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3298] 1000 3298 32794 380 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3299] 1000 3299 32730 427 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3300] 1000 3300 32832 347 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3301] 1000 3301 32732 427 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3302] 1000 3302 32661 430 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3303] 1000 3303 32728 349 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3304] 1000 3304 32728 334 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3305] 1000 3305 32730 427 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3306] 1000 3306 32732 429 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3307] 1000 3307 32886 423 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3308] 1000 3308 32732 426 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3309] 1000 3309 32732 429 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3310] 1000 3310 33085 1567 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3311] 1000 3311 32792 403 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3312] 1000 3312 33083 366 3 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3313] 1000 3313 32730 427 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3314] 1000 3314 32732 426 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3315] 1000 3315 33088 329 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3316] 1000 3316 32794 386 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3317] 1000 3317 32818 331 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3318] 1000 3318 32920 405 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3319] 1000 3319 32796 365 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3322] 1000 3322 32693 372 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3323] 1000 3323 32730 430 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3324] 1000 3324 33024 355 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3325] 1000 3325 32794 586 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3326] 1000 3326 32730 430 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3327] 1000 3327 32732 426 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3328] 1000 3328 33087 341 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3329] 1000 3329 32736 398 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3330] 1000 3330 32794 342 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3331] 1000 3331 32792 403 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3332] 1000 3332 32732 427 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3333] 1000 3333 32730 430 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3334] 1000 3334 33216 358 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3335] 1000 3335 32732 429 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3336] 1000 3336 32732 430 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3337] 1000 3337 32761 403 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3338] 1000 3338 32817 374 0 0 0 httpd
Aug 2 16:35:32 localhost kernel: [ 3339] 1000 3339 32755 366 0 0 0 httpd
aquan888
2014-8-2 20:39
0 httpd
Aug 2 16:35:35 localhost kernel: [ 3829] 1000 3829 32730 1439 0 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3830] 1000 3830 32730 1466 0 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3831] 1000 3831 32761 1607 0 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3832] 1000 3832 32661 1367 0 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3833] 1000 3833 32730 1466 0 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3834] 1000 3834 33029 1875 0 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3835] 1000 3835 32812 1671 0 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3836] 1000 3836 32732 1473 0 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3837] 1000 3837 33286 2236 1 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3838] 1000 3838 33029 1890 0 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3839] 1000 3839 32661 1368 2 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3840] 1000 3840 32601 1521 2 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3841] 1000 3841 32732 1471 0 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3844] 1000 3844 33154 1984 0 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3847] 1000 3847 32730 1541 0 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3850] 1000 3850 32800 1615 0 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3855] 1000 3855 33286 2183 0 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3858] 1000 3858 32732 1441 0 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3861] 1000 3861 33157 2015 2 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3862] 1000 3862 32671 1502 0 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3870] 1000 3870 32828 1648 0 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3881] 1000 3881 32732 1450 2 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3882] 1000 3882 32732 1441 2 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3883] 1000 3883 33025 1899 0 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3890] 1000 3890 32697 1566 0 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3891] 1000 3891 32732 1468 3 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3892] 1000 3892 32732 1525 3 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3899] 1000 3899 32661 1358 3 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3900] 1000 3900 32697 1618 2 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3901] 1000 3901 32826 1583 0 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3906] 1000 3906 32343 1063 3 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3907] 0 3907 24203 327 3 0 0 sshd
Aug 2 16:35:35 localhost kernel: [ 3908] 0 3908 24266 370 3 0 0 sshd
Aug 2 16:35:35 localhost kernel: [ 3909] 74 3909 16436 251 3 0 0 sshd
Aug 2 16:35:35 localhost kernel: [ 3910] 74 3910 16436 233 3 0 0 sshd
Aug 2 16:35:35 localhost kernel: [ 3911] 0 3911 24266 339 1 0 0 sshd
Aug 2 16:35:35 localhost kernel: [ 3912] 74 3912 16436 234 3 0 0 sshd
Aug 2 16:35:35 localhost kernel: [ 3913] 1000 3913 31935 578 2 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3914] 0 3914 15547 213 3 0 0 sshd
Aug 2 16:35:35 localhost kernel: [ 3915] 1000 3915 31773 497 3 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3916] 1000 3916 31773 498 2 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3917] 1000 3917 31773 498 2 0 0 httpd
Aug 2 16:35:35 localhost kernel: [ 3918] 0 3918 16100 73 3 0 0 sshd
Aug 2 16:36:07 localhost kernel: mysqld invoked oom-killer: gfp_mask=0x280da, order=0, oom_adj=0, oom_score_adj=0
Aug 2 16:36:07 localhost kernel: mysqld cpuset=/ mems_allowed=0
Aug 2 16:36:07 localhost kernel: Pid: 3941, comm: mysqld Not tainted 2.6.32-358.el6.x86_64 #1
Aug 2 16:36:07 localhost kernel: Call Trace:
Aug 2 16:36:07 localhost kernel: [<ffffffff810cb5d1>] ? cpuset_print_task_mems_allowed+0x91/0xb0
Aug 2 16:36:07 localhost kernel: [<ffffffff8111cd10>] ? dump_header+0x90/0x1b0
Aug 2 16:36:07 localhost kernel: [ 3383] 1000 3383 32336 423 3 0 0 httpd
