雙網(wǎng)卡,有一塊網(wǎng)卡ping不通。。。。
[打印本頁(yè)]
lfghx
2012-2-24 10:20
root@111111111
~]# ifconfig
eth0 Link encap:Ethernet HWaddr 00:24:1D:1D:73:FA
inet addr:192.168.1.185 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:71148 errors:0 dropped:0 overruns:0 frame:0
TX packets:90586 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:10343178 (9.8 MiB) TX bytes:73561246 (70.1 MiB)
Interrupt:122 Base address:0x2000
eth1 Link encap:Ethernet HWaddr 54:E6:FC:70:5A:F2
inet addr:192.168.123.216 Bcast:192.168.123.255 Mask:255.255.255.0
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:7938 errors:15 dropped:0 overruns:0 frame:0
TX packets:20 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1000941 (977.4 KiB) TX bytes:1764 (1.7 KiB)
Interrupt:169 Base address:0x2000
[root@111111111~]# iptables -vL
Chain INPUT (policy ACCEPT 0 packets, 0 bytes)
pkts bytes target prot opt in out source destination
Chain FORWARD (policy ACCEPT 0 packets, 0 bytes)
Chain OUTPUT (policy ACCEPT 0 packets, 0 bytes)
[root@1111111111 ~]# route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
192.168.123.0 0.0.0.0 255.255.255.0 U 0 0 0 eth1
0.0.0.0 192.168.1.1 0.0.0.0 UG 0 0 0 eth0
第一塊網(wǎng)卡可以正常工作,第二塊ping不通。。。。
rainmanyzc
2012-2-25 12:31
是不是沒(méi)有插好,
lam
2013-2-21 15:07
同樣遇到這個(gè)問(wèn)題,不知道有沒(méi)有辦法解決
2013-2-21 20:42
不同網(wǎng)段?
else
2014-8-2 08:43
回復(fù)
4#
不同網(wǎng)段的,不好保存,每一次,重啟,都要設(shè)置
