標(biāo)題: [求助] 重裝系統(tǒng)出錯(cuò) [打印本頁]
作者: yzxk    時(shí)間: 2014-6-5 17:13     標(biāo)題: 重裝系統(tǒng)出錯(cuò)
wdcp在后臺重設(shè)了sql的小內(nèi)存方案后,數(shù)據(jù)庫掛掉了,查找論壇有關(guān)”無法連接mysql,請檢查mysql是否已啟動及用戶密碼是否設(shè)置正確“的帖子后,發(fā)現(xiàn)有這個(gè)問題的不在少數(shù),但按照眾多的解決方法嘗試后,居然都沒有用,無法修復(fù)了,我是外行,想不到別的方法了,于是只好考慮重新安裝控制面板,但安裝的時(shí)候,依然有有關(guān)數(shù)據(jù)庫錯(cuò)誤的提示,不知道怎么回事,看樣子重裝都不行 。以下是重裝時(shí)候錯(cuò)誤信息部分:
installing mysql,this may take a few minutes,hold on plz...
configure in progress ...
make in progress ...
make install in progress ...
Starting MySQL. ERROR! Manager of pid-file quit without updating file.
/www/wdlinux/mysql/bin/mysqladmin: connect to server at 'localhost' failed
error: 'Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)'
Check that mysqld is running and that the socket: '/tmp/mysql.sock' exists!
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)
pcre installing...
installing nginx...
installing httpd...
installing libiconv...
installing php...
----Install Error: php make err -----------
You have new mail in /var/spool/mail/root
重裝,在文件下載后(用了20多分鐘),執(zhí)行安裝命令后,裝了好久啊,估計(jì)至少有 分鐘,好像不太正常
請教大神們,怎么才好啊。。。。。。
