MySQL Daemon failed to start. 啟動(dòng)不了
[打印本頁(yè)]
tianwei
2014-5-7 12:01
Version: '5.1.63' socket: '/tmp/mysql.sock' port: 3306 Source distribution
140409 20:58:57 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: Normal shutdown
140409 20:58:57 [Note] Event Scheduler: Purging the queue. 0 events
140409 20:58:57 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: Shutdown complete
140409 20:58:57 mysqld_safe mysqld from pid file /www/wdlinux/mysql-5.1.63/var/localhost.localdomain.pid ended
140409 20:58:57 mysqld_safe Starting mysqld daemon with databases from /www/wdlinux/mysql-5.1.63/var
140409 20:58:57 [Note] Event Scheduler: Loaded 0 events
140409 20:58:57 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: ready for connections.
tianwei
2014-5-7 14:56
查看了原因缺少mysql.sock
但是運(yùn)行/www/wdlinux/mysql/bin/mysql_install_db --user=mysql
/www/wdlinux/mysql/bin/mysqld_safe --user=mysql &
后生成/tm/mysql.sock了,重啟服務(wù)也正常,但只要重啟服務(wù)器又是少mysql.sock
tianwei
2014-5-8 00:18
管理員,能否回復(fù)下呢?那些權(quán)限檢查工具都用,正常,磁盤也沒滿
